Понедельник, 26.10.2026, 09:24
Главная Redgum RGi 120ENR - ФорумРегистрацияВход
Redgum RGi 120ENR
НиколайДата: Четверг, 12.12.2013, 09:17 | Сообщение # 1
Redgum RGi 120ENR
Технические характеристики Redgum RGi 120ENR - Power Output: 155 + 155 Watt/Ch RMS (293 + 293 W RMS - transient)
- Harmonic Distortion: less than .009% (below Clipping)
- Intermodulation Distortion: less than .005% (below Clipping)
- Signal to noise: greater than 100dB
- Input Impedance: 10K ohms (matches 600 ohms - 50K ohms)
- Slew Rate: greater than 65Volt / microsecond
- Damping Factor: greater than 800
- Frequency Response: 0.8 Hz to 80KHz (-3dB points)
- Peak Current: greater than 120 amps
- Audio Inputs: CD1, AV1, DVD, CD2, AV2
- Suggested Speakers: REDGUM RGS Lucens or RGS Regnans (shielded Floorstanding Speakers)
- Cabinet Finish: high gloss solid Red Gum wood fascia, gloss black thick steel chassis, heavy duty "Sign Wave" heat sink base
- Options: choice of Dual Mono or Single volume; key switch, rocker or
toggle switch; alternative front panels can made to order (at additional
charge) or as supplied by customer; Other possibilities? Just talk to
us about it!
- Warranty: Full 7 year Warranty
- Dimensions: 420mm (W) x 360mm (D) x 95mm (H)
- 16.5in (W) x 14.2in (D) x 3.75in (H)
- Shipping weight: 11 kg / 24 lb (8.2 kg/18 lb cubic)
Обзор в PDF файле: ТУТ
Прикрепления: 1465092.jpg (65.7 Kb) · 3624248.jpg (57.1 Kb) · 6312793.jpg (205.6 Kb) · redgum_rgi120en.pdf (1.94 Mb)
